  2. Adams Car
  3. How to Create a Clutch System for an Attachment in Matlab...
  • Subscribers 1
  • Views 174
How to Create a Clutch System for an Attachment in Matlab-Adams Car Cosim?
canpolatb20
canpolatb20 over 4 years ago
I want to make ARB noneffective dependent on a state variable. Whether it should be active or nonactive, changing with the value of the state variable. It would be amazing to provide zero effect (for the specified joint) in Simulink, but I am open to any suggestions that are linked to Adams/Solver.
  • Jesper Slattengren
    0 Jesper Slattengren over 4 years ago
    This is trivial and can be done in a multitude of ways. The easiest is to define the connection between left and right side of the clutch using a rotational SForce to emulate the clutch (and even the ARB itself if required).
    The function would then be:
    VARVAL(ARB_Active)*(-K_arb*AZ(M2,M1) - C_arb*Wz(M2,M1,M1))
    and you can control the activity of the ARB by changing the solver variable ARB_Active between 0 and 1.
  • MartinKieltsch
    0 MartinKieltsch over 4 years ago
    I prefer another facet of the mentioned multitude:
    Using a GCON between two markers in the middle of the ARB that ususually would have been connected with a fixed joint.
    Constraining them with a let's say spherical and a GCON with function = AZ(I/J)*Varval(on_off_variable) will make the torsional connection switchable via a state variable.
