  2. Adams Car
  3. How can I calculate the spring coefficient (k) of leaf spring...
  • Subscribers 1
  • Views 157
How can I calculate the spring coefficient (k) of leaf spring in Adams/Car?
canpolatb20
canpolatb20 over 3 years ago
I've created a leaf spring using "Leaf Spring Editor". However, I've been struggling to draw its Load/Deflection diagram. For that purpose, which parameters should I use in x-axis and y-axis in the postprocessor interface?
For instance, I've been choosing "lfl_seat_leaf_spr_XFORM.Z" for x-axis and "lfl_axle_bush_leaf_spr.FZ" for y-axis but I am not sure that is the correct way to determine its vertical spring coefficient.
  • PJ
    0 PJ over 3 years ago
    You can assemble the leafspring with a rigid axle suspension subsystem, and then simulate a parallel wheel travel event using suspension testrig. Use rigid tires (extremely high stiffness) Then plot "Wheel load vertical force" vs "Wheel travel" plot for any side (left or right). This should be near the stiffness of the leaf spring.
  • canpolatb20
    0 canpolatb20 over 3 years ago
    Thank you for your reply. I will be considering this method during my design process.
