  2. Adams Car
  3. modifying aevhybrid's in wheel motors wheights and gear...
  • Subscribers 1
  • Views 335
modifying aevhybrid's in wheel motors wheights and gears
Yannic Wulfdeit
Yannic Wulfdeit 11 months ago
When I modify my in-wheel-motors motor diameters and weight, or gears to fit my actual vehicle my model stops passing static equilibrium
  • Alexis Del Rio
    0 Alexis Del Rio 11 months ago
    can you show the Equilibrium error, please?
  • Yannic Wulfdeit
    0 Yannic Wulfdeit 11 months ago in reply to Alexis Del Rio
    Okay so I reset all my changes to my wem substystem and there seems to be a different issue with my model. When simulating constant radius cornering the simulation stops after a fraction of the time and looks as follows
    Open Loop simulations work though
    LONGITUDINAL SETUP ITERATIONS = 2
    Simulation Step Function Cumulative Integration Elapsed
    Time Size Evaluations Steps Taken Order Time
    ___________ ___________ ___________ ___________ ___________ ________
    0.00000E+00 5.00000E-04 0 0 1 2.94
    ---- START: WARNING ----
    PAC2002: Fz larger than FZMAX: corrected to FZMAX
    Simulation time is 2.500000000E-04
    ---- END: WARNING ----
    PAC2002: Camber angle exceeds validity range -> corrected to CAMMIN-CAMMAX range
    PAC2002: Long. slip exceeds validity range -> corrected to KPUMIN-KPUMAX range
    ---- START: ERROR ----
    Adams can not solve the equations of motion because the mechanism has
    "locked up". At least one constraint can no longer be satisfied.
    Adams is unable to satisfy the constraint for: FxdJnt/108 X Delta.
    Simulation time is 8.000001604E-02
    ---- END: ERROR ----
    Dynamic Solution stopped.
    End Simulation
    Simulate status=-124
    SIMULATE command failed for minimaneuver: STEADY_STATE
    Aborting Execution.
    Adams Solver (C++) run terminating due to STOP requested by user.
    Termination status=-995
    An end condition has been sensed.
    - VELOCITY: 50.470869 >> 11.111110 (+/- 0.000000)
    filter time: 0.000000, delay: 0.000000
    Ending current mini-maneuver...
    Terminating Adams Car usersubs...
  • Alexis Del Rio
    0 Alexis Del Rio 11 months ago in reply to Yannic Wulfdeit
    Can you tell me the constant radius cornering setting you ran so I can replicate?
