  2. Adams Car
  3. Adams car suspension analysis error. (Initialization of...
  • Subscribers 1
  • Views 4
Adams car suspension analysis error. (Initialization of Suspension Characteristics, Calculations Failed error)
SamsonAkash
SamsonAkash over 5 years ago
I had trying to analysis my own created template, but when I try a suspension analysis, I got suspension characteristics calculation failed error. Can some one help me to solve this. I attached my assembly file, subsystem file with error msg file.
Attached Files (5)
Rear_H_arm.suq.zip
trail2.asq.zip
Rear_H_arm.sub.zip
it2_parallel_travel.msg
trail2.asy.zip
  • jozef.bucha
    0 jozef.bucha over 5 years ago
    You have to send .tpl file. I can see .msg, .sub, suq, .asy, .asq. Without template it cannot be opened
    Jozef
  • SamsonAkash
    0 SamsonAkash over 5 years ago
    thanks jozef. I attached my template file.
    Attached Files (1)
    _H_arm_suspension.tpl.zip
  • jozef.bucha
    You have problem with suspension parameters array
    In tree go to Elements/Data_Elements/ and delete suspension parameters array, and create new one like we spoke yesterday.
    Than you will have new problem with static equlibrium during wheel travels analysis. Spring is missing in the suspension, there is just damper, but no spring.
    I did not have time to add spring a test it
    Jozef
  • SamsonAkash
    thanks jozef. I debugged my parameter and communicator errors and my kinematic analysis was success but as you mentioned earlier the static equilibrium was failed even though I added spring to my model. But as far as I know the error message was due to my spring only. can you please help me to solve this problem by rectifying what mistake i had done. I attached the .msg, .tpl, .asy, and .sub files.
    Samson
    Attached Files (1)
    New folder.rar
