  2. Adams Car
  3. Adams Car analysis failed (Toe out)
  • Subscribers 1
  • Views 12
SamsonAkash
SamsonAkash over 5 years ago
Hi guys, I am was trying to create an Baja ATV in Adams car. During acceleration analysis I get Toe out in front suspension geometry and it got steer itself even the steer input was locked. I was trying constant radius cornering and its getting failed. So please take a look at those video and have a look at my file and help me to solve my problem.
thanks in advance
Attached Files (3)
ACCLERATION STRAIGHT LINE.avi
ACCLERATION LOCKED.avi
Rage.zip
  • jozef.bucha
    0 jozef.bucha over 5 years ago
    Hello, to check your model we need also templates and subsytems not just assembly.
    Jozef​
  • Jesper Slattengren
    0 Jesper Slattengren over 5 years ago
    Too soft bushings? Try running with the suspensions and steering set to "kinematic".
  • SamsonAkash
    0 SamsonAkash over 5 years ago
    Hi, thanks for replaying. i tried running with kinematic but it didn't work. I attached my whole directory folder in my drive and link is below. Please take a look and help me to solve this problem.
    drive.google.com/.../view
  • SamsonAkash
    Hi, guys did anyone saw my post. ​
  • jozef.bucha
    These are your communicators info during assembly opening
    WARNING: The following input communicators were not assigned during assembly:testrig.cis_max_brake_value
    testrig.cis_air_density
    testrig.cis_aero_frontal_area
    testrig.cis_drag_coefficient
    testrig.cis_drag_brake_coefficient
    testrig.cis_downforce_coefficient
    testrig.cis_downforce_brake_coefficient
    testrig.cis_front_aero_location
    testrig.cis_crankshaft_ratio
    testrig.cis_transmission_efficiency
    testrig.cis_downshift_RPM
    testrig.cis_upshift_RPM
    testrig.cis_aero_drag_force
    testrig.cil_svs_ride_height_rear
    testrig.cir_svs_ride_height_rear
    testrig.cis_svs_trim_part
    testrig.cis_svs_trim_part_loading
    testrig.cis_front_brake_max_torque
    testrig.cis_rear_brake_max_torque
    testrig.cis_brake_ratio
    testrig.cis_overall_steering_ratio
    testrig.cil_toe_angle_rear
    testrig.cir_toe_angle_rear
    testrig.cil_camber_angle_rear
    testrig.cir_camber_angle_rear
    testrig.cis_test_equipment_gyro
    testrig.cis_instrumentation_gyro
    testrig.cis_driver_hip_point
    testrig.cil_wheel_center_marker_rear
    testrig.cir_wheel_center_marker_rear
    testrig.cil_spindle_rise_rear
    testrig.cir_spindle_rise_rear
    TR_Steering.cis_test_equipment_gyro
    Front_tire_baja.cis_wheel_force_transducer
    Rear_tire_baja.cil_toe_angle
    Rear_tire_baja.cir_toe_angle
    Rear_tire_baja.cil_camber_angle
    Rear_tire_baja.cir_camber_angle
    Rear_tire_baja.cis_wheel_force_transducer
    WARNING: The following input communicators did not match with unique output communicators:
    baja_powertrain.cil_tire_force
    matched with: Front_tire_baja.col_tire_force
    also matches: Rear_tire_baja.col_tire_force
    baja_powertrain.cir_tire_force
    matched with: Front_tire_baja.cor_tire_force
    also matches: Rear_tire_baja.cor_tire_force
    I found that you have powertrain subsystem minor role any, it should by rear (your vehicle is rear driven),
    second thing, add brake subsystem
    third thing
    those communicators
    are needed to be connected
    fourth thing spring in front and rear subsystem are pointing to different database. I do not know why but i was not able to to change them to some existing spring property file from shared database. Program was mentioning about different variant, which is not there. I was able to change them only in text editor.
    Jozef
