  2. Adams Car
  3. Problem with suspension model
  • Subscribers 1
  • Views 366
Riccardo Biasi
Riccardo Biasi 8 months ago
I have been using Adams Car for several weeks now, specifically for my university thesis involving our Formula Student racing team.
I started with the Formula Student model provided in your webinars and modified it to reflect our car's specific decoupled suspension layout.
However, I have encountered a persistent error that is preventing me from proceeding with my simulations.
Whenever I attempt to run a simulation, the system returns the message that you can see on the attached photo.
I understand this is likely a model configuration issue. Since I am relatively new to Adams Car, I am having trouble locating the root cause of the error and determining the necessary steps to resolve it.
Could you please provide some guidance or assistance on how to troubleshoot this specific error?
Thank you for your time and help.
Best regards,
Riccardo Biasi
nexus.hexagon.com/.../2870.fsae_5F00_decupling.zip
  • MC202509189142
    0 MC202509189142 8 months ago
    Thread moved from How to use Nexus Community
  • Jesper Slattengren
    0 Jesper Slattengren 8 months ago
    I don't think the problem is in the template, that looks pretty normal. More likely it is in your model data.
    The error message simply says that the static solution was not successful. You can try to increase the max number of iterations from 25 t0 250, that might help.
    But most likely your spring data is wrong. Probably the preload is not correct, that is the most common problem.
    Try to run the Dynamic suspension event, increasing the motion of the wheel from -20 mm to +20 mm. This can help you pinpoint the error. Bit there is a chance that this won't work either because it probably will try a static solution first.
  • Vojtech Brychta
    0 Vojtech Brychta 8 months ago
    Hello, what is the setting of the analysis you're trying to run?
    As suggested bellow, try to run a dynamic event, it sometimes shows you what could be wrong.
    Sincerely,
    VB.
