  2. Adams
  3. ADAMS INSIGHT SCRIPT
  • Subscribers 3
  • Views 21
mfarhan
mfarhan over 9 years ago
Renaming ADAMS Insight abbreviation
Renaming ADAMS/Insight (factor & response) is tedious.
As shown in the figure above, I have to rename the (abbreviation : r_06) to (mode16_imaginary).
Imagine that repeating this process for hundreds of (factors & responses). Its tedious.
Is there any script or way that I can rename each of these (factors & response) abbreviation automatically?
  • Jesper Slattengren
    0 Jesper Slattengren over 9 years ago
    First, why would you like to have the abbreviation the same as the name? The reason abbreviations exist is that they should be easier to read in complex tables and figures. I do often rename the abbreviation, but to something much shorter thant he anme, such as 'm16im' in your case.
    But anyway, the ADAMS/Insight experiemtn file is a xml file. Easy to edit and a with a good text editor you can quickly create a macro that
    1. Search for factor name="
    2. Copy the string after this.
    3. Search for "abbreviation">
    4. Replace the string after this with the copied string.
    Using an xml editor could make it even simpler.
    Save your file, open insight and open up the experiment.
  • Kent West
    0 Kent West over 9 years ago
    Tagging this thread for #Insight ...
    I was annoyed by this recently, too, so I logged a Product Enhancement request on this with a suggestion similar to yours. I've also created a script that will live here:
       simcompanion.mscsoftware.com/.../index
    but the darned attachment isn't showing up at the moment. (grrrrr). We should have that fixed shortly, but here's how it works (download attached script..):
    c:\MSC.Software\Adams\2017\common\mdi.bat python insight_make_abbrevs.py exp.xml out_file.xml
    where:
    insight_make_abbrevs.py    = attached file, saved to your working directory
    exp.xml                                   = name of your Insight experiment, in working directory
    out_file.xml                            = name of new experiment, created in working directory
    Attached Files (1)
    insight_make_abbrevs.py.zip
