  2. Adams
  3. Is it possible to fetch a variable value which is referenced...
  • Subscribers 3
  • Views 15
Is it possible to fetch a variable value which is referenced by other variable ?
darshan.v
darshan.v over 9 years ago
As per below code, I have created variables (body_1, body_2) using other variable's string values (body). Now I want to access "body_1" in my code but I suspect it is possible to access it.
_________________________________________________________
var set var = $_self.part_name string = &
"body", &
"subframe", &
"upright"
var set var = (eval("$_self."//($_self.part_name[1]))) string = &
"body_1", &
"body_2", &
var set var = (eval("$_self."//($_self.part_name[2]))) string = &
"subframe_1", &
"subframe_2", &
var set var = (eval("$_self."//($_self.part_name[3]))) string = &
"upright_1", &
"upright_2", &
acar too mess mess=(eval($_self.part_name[1].string_value[1]))
_____________________________________________________________________
Darshan M. Vachhani
AF Consult, Sweden
  • Rishikesh Mokashi
    0 Rishikesh Mokashi over 9 years ago
    Hi Darshan,
    Something like this should work:
    variable set variable_name = variable_names string_value = "body_1", "body_2"
    variable set variable_name=myvar str=(eval(variable_names[1]))
    Which yields:
    Object Name : .MODEL_1.myvarObject Type : Variable
    String Value(s) : body_1
    Comment String : None
    Rishi
  • darshan.v
    0 darshan.v over 9 years ago
    Hi Rishi,
    Thank you for the reply.
    Actually I want to access values of variables which is created by other variable names.
    In my example code, I want to access "body_1" through the variable "$_self.part_name" which I have created in the beginning.
    BTW, I got the resolution as below. May be not proper but it works for me.
    acar too mess mess=(eval(STOO("$_self."//($_self.part_name[1])).string_value[1]))
    acar too mess mess=(eval(STOO("$_self."//($_self.part_name[1])).string_value[2]))
    This gives output as,
    body_1
    bosy_2
    Thank you.
    Darshan M. Vachhani
    AF Consult, Sweden
  • Jesper Slattengren
    0 Jesper Slattengren over 9 years ago
    Why do you use string values instead of object types? Then you shouldn't have to use the STOO function.
    I figure something like $_self.part_name.object_value[1] should do the trick.
