  2. Adams
  3. ADAMS/CAR DOE for Bushings
  • Subscribers 3
  • Views 10
jsph_inc.
jsph_inc. over 9 years ago
Hi All,
I am looking to perform a DOE on a suspension assembly. What is the best way to do this? Could I use ADAMS/Insight to do this? I don't see an ADAMS/Insight plug-in for ADAMS/Car so I'm not sure...
​The DOE is to try combinations of bushing rates at all inboard mounting locations. Since bushings are defined in ADAMS/Car as bushing files, could this be done as a DOE where the files get swapped?
​I have access to HEEDS software, would that be good to use?
​thanks!
​joe.
  • jozef.bucha
    0 jozef.bucha over 9 years ago
    Hello Joe,
    You have to look better for Insight in Acar :).
    Maybe this link will help you:
    simcompanion.mscsoftware.com/.../index
    Regards Jozef
  • jsph_inc.
    0 jsph_inc. over 9 years ago
    Oh yes, found it. Thanks!
    Would insight allow you to change bushing files, or is it geared only toward changing numerical values? ​
  • jozef.bucha
    If i remmember correctly, bushing is described in adm file for solver as spline, insinght is using factor to chnge value, afaik you are using one property file
  • Jesper Slattengren
    0 Jesper Slattengren over 9 years ago
    Scale factor, offset and preload shows up in Insight as available parameters for the DOE.
    If you want to change property files, it will take a bit more work.
