  2. Adams
  3. carbon fiber 0 90 epoxy and carbon fiber 11 prepreg
  • State Verified Answer
  • Subscribers 3
  • Views 22
asaad
asaad over 9 years ago
Hey everyone! I am looking for more information on these two materials within Adams. Within the helpfiles I do find the explanation for orthotrpoic and anisotropic materials and the neccessary constans (c11,c12,... E,Gxy,Gyz), but I'd like to find out if I can change the orientation of the fibres from 090 to maybe -45 45. And what does 11 mean in the prepreg material?
Thanks a lot in advance!
  • Ken Walker
    0 Ken Walker over 9 years ago
    @Asaad Sellmann​, your topics are confusing.  Are you using Adams or Patran? PCL is the Patran Customization Language. I can't help much with Adams, but will provides some basic composites material info.
    Regarding directions, 11, 22, etc refer to the material directions. So 11 represents material properties in the 0 deg direction, and 22 represents material properties in the 90 deg direction. FEA codes use a "Material angle" to represent the direction of the 0 deg (11 ply) on an element. That's how you change 0/90 to -45/45 orientation. Not sure how this is done in Adams.
  • asaad
    0 asaad over 9 years ago
    Oh I'm sorry, the topic was not chosen on purpose..actually I am wondering why these Topic buttons appeard anyway..?!
    Thank you for your answer! That is giving me some insight, to understand the constants a bit more^^
  • Ken Walker
    good question: why these Topic buttons appeared?
    others may be wondering the same.
    The system tries to "auto-magically" select topics based on the contents of your question/post . That helps assign them to appropriate topics and sub-topics.
    Adams was added because you mentioned it in the message.
    No telling why PCL and Customization as added....
    Also you can manually add (or remove) topics
  • asaad
    All right, good to know! I'll check that next time before sending the Post!
    auto-magically sounds good :D
