  2. Adams
  3. Moments and Forces output of Flexible bodies is zero?
  • Replies 12
  • Subscribers 3
  • Views 18
shuai.wang
shuai.wang over 9 years ago
Hi, Everyone.
I met a problem of outputting responses of a flexible body.
I just use a cantilever beam as a flexible body in ADAMS, and applying a moment load at one side, the 'total force on point' and 'total torque on point' output of mass center marker are all Zero. I checked the displacement is correct, but have no idea about the forces and moments.
Does anybody know the problem, I am a beginner of ADAMS and would be really appreciated for your kind help. Thank you very much!
Shuai
  • jpatterson
    0 jpatterson over 9 years ago
    Did you attach your cantilever to ground? What are the reactions there...???
  • shuai.wang
    0 shuai.wang over 9 years ago
    Thanks for your answering. I attached cantilever to the ground with a fixed joint.
    The reactions on the joint are normal and counteracted with the load. But internal force along the cantilever are all zero.
  • jpatterson
    This is the behavior I would expect. I'm pretty sure ADAMS is only going to report forces/moments where you attach a constraint or force element...
  • shuai.wang
    Thank you, Jpatterson. But is there any way of outputting the forces/moments at specific points on the flexible body?
  • jpatterson
    Not that I know of. I'm curious why you want them...???
