  2. Adams
  3. Can I run my .adm with Requests and a flex body in Fortran...
  • Subscribers 3
  • Views 16
Can I run my .adm with Requests and a flex body in Fortran Solver?
SHonodel
SHonodel over 9 years ago
I'm trying to run my ADAMS model with Solver to get my Requests files created. This has worked fine until I added a flex body. Now I get an mtx failure message about not having access to the folder. However, the mtx file was created. When I try to run the adm file in Solver, I get a Windows error that Solver has failed. Is this likely a corrupt mtx file, or something else? Is there something I should look for in the mtx file to see if that's the problem?
  • MK202610123211
    0 MK202610123211 over 8 years ago
    Usually people tend to forget to deactivate the rigid body modes of the flex body ...
  • jozef.bucha
    0 jozef.bucha over 8 years ago
    You sad it was working with requests file until you add flex body. Did you try with flex body without requests. Also check chapter in adams/flex documentation about possible limitations of using fortran solver with flex bodies (force limitations, joints limitations,...)
  • SHonodel
    0 SHonodel over 8 years ago
    Thanks, Martin and Jozef for responding.  I think the problem was that I only have one Flex license and I happened to have the model still open in View when I tried to run Solver.​  I closed View and it worked.  I just wish there were better diagnostic messages.  I'm running ADAMS 2013.
