  2. Adams
  3. How to rotate and translate a part during run time simulation...
  • State Verified Answer
  • Replies 14
  • Subscribers 3
  • Views 22
How to rotate and translate a part during run time simulation?
Tuan Nguyen
Tuan Nguyen over 7 years ago
  • Maziar R
    0 Maziar R over 7 years ago
    Hi Tuan,
    You can make use of the Adams Solver Command
    MARKER/ID,QP=...
    to move a part around provided that the marker is the anchor/reference marker of that part. You also need to make sure that the dependencies are all properly addressed.
    Check out the attached model. MARKER/2 which is the anchor marker of the box is used to move it around at time 0.2 seconds. However, the dependent object JOINT/1 whose ground marker is MARKER/4 should also be moved. As a result, MARKER/4 is also moved to address the dependency issue.
    Maziar
    Attached Files (1)
    test_mod.cmd.zip
  • MK202610123211
    0 MK202610123211 over 7 years ago
    Otherwise a GCON would be my favorite pick.
  • Tuan Nguyen
    0 Tuan Nguyen over 7 years ago
    Thank you, Maziar !
    I see the part II moves as expected.
    My problem seems a little bit more complicated.
    I need to move a part based on of the translation vector and rotation matrix of another part in the last successful integration step.
    Some thing should relate to subroutine, right ? But I have never tried subroutine and don't know is this possible to do my idea.
    Any suggestion?
  • MK202610123211
    Well this is what a GCON does, but I won't type it a third time.
  • Tuan Nguyen
    @Martin Kieltsch​ I looked at some examples of GCON in this and old forum. I see GCON could be nice way to constrain object.
    However in my situation, I need to input the previous displacement of another part which probably could't get using acf file, but might be with subroutine .
    @Maziar Rostamian​ Would you mind suggesting any subroutine I could use to move a part per integration step ?
    I have just started with Adams but got more experience with Marc subroutine.
    My thanks!
