  2. Adams
  3. Is there a way to restart a solver run at some specified...
  • State Verified Answer
  • Subscribers 3
  • Views 9
Is there a way to restart a solver run at some specified timepoint from the .res file? (maybe with different step size?)
GJJP
GJJP over 7 years ago
  • Maziar R
    0 Maziar R over 7 years ago
    From what I understand, you would like to have a different the output step size at some point in the simulation. If this is correct, you can simply use a new line of SIM/DYN command in your Solver Script like so:
    Instead of the following solver script:
    SIMULATE/DYNAMIC, END=1.0, DTOUT=0.01
    You can use the following:
    SIMULATE/DYNAMIC, END=0.5, DTOUT=0.01
    SIMULATE/DYNAMIC, END=1.0, DTOUT=0.005
    This is provided that you know when you'd like to change your output step. If you do not know that exact time, you can use a sensor that is triggered by an input other than time.
    Please let me know whether or not this helps.
    Maziar Rostamian
    MSC Software
  • MK202610123211
    0 MK202610123211 over 7 years ago
    Other than that, you may be interested in the SAVE / RELOAD command that you can use in the acf file.
    The above can stop and restart the simulation but not go back in time. With save/reoad you can save let's say the static equillibrium, run an analysis and after that go back to the saved state change a parameter and start another analysis.
  • GJJP
    0 GJJP over 7 years ago
    Hi Mazier, thanks for your answer.
    Unfortunately I did not make mayself completely clear: I would like to restart a solver-run after it has already been running (maybe because I want to change the step sizes as described above after reviewing the already running simulation, because I want to investigate a certain event in more detail, or maybe even because the simulation stopped because of some external IT problem, e.g. power loss).
    I've already used the method with the sensor you mentioned, but sometimes even that is not sufficient - you cannot always tell beforehand under which conditions you should change the step size.
    Thanks again for your help,
    Gernot
  • MK202610123211
    Not 100% sure, but from what I know SAVE/RELOAD should do that job, too.
    If you have your original acf and do a SAVE at some point of time, the saving is done into a file.
    When you later decide to do a second analysis (i.e. run the same adm with a modified, second acf), you should be able to start the acf with a RELOAD command on the mentioned file and then continue from the saved position/time as desired.
  • GJJP
    Thanks, this was a very helpful hint for me!
