  2. Adams
  3. Raw Vs Fitted Data
  • State Verified Answer
  • Subscribers 3
  • Views 6
Raw Vs Fitted Data
m.derbas
m.derbas over 7 years ago
Hey all,
I have some data for bushings that i need to create a property file for
The Bushings have a strong hysteresis and therefor they have multiple forces for the same displacement value, will this be a problem or should i fit some data to extract only the moving average or moving median for example ?
If both ways are correct, then what would be better all in all considering also simulation time ?
thanks in advance !
  • Jesper Slattengren
    0 Jesper Slattengren over 7 years ago
    You should use an xml-bushing file. That gives you many more options than the TO file format and a different bushing editor.
    So modify a xml-bushing file from the shared cdb and then use the documentation to study the different options. It seems like the Hysteretic formulations should work well for you.
  • m.derbas
    0 m.derbas over 7 years ago
    Thanks !​
