  2. Adams
  3. How to find minimum value after certain time in a Simulation...
  • Subscribers 3
  • Views 7
How to find minimum value after certain time in a Simulation?
hkalupuk
hkalupuk over 6 years ago
If simulation time is 10 seconds and I want to find the minimum or maximum values that comes after 5 seconds of simulation time.​
  • MK202610123211
    0 MK202610123211 over 6 years ago
    The answer is hidden here:
    simcompanion.hexagon.com/.../how-to-get-the-index-of-maximumminimum-value-of-a-output-set
  • hkalupuk
    0 hkalupuk over 6 years ago
    Thanks for the answer @Martin Kieltsch​ , But, I want to find after certain simulation time. In the description of the question I mentioned it "If simulation time is 10 seconds and I want to find the minimum or maximum values that comes after 5 seconds of simulation time.​" How to get that. Because in my case there are values which are the smallest and largest but before 5 seconds of simulation time I don,t need them. I need values from the 5.1th second of simulation time.
  • MK202610123211
    With a time step of 0.01 s it'd be:
    MAX(.model.analysis.my_request.values[500:1000]
    Another way would be to create a request with an if-function that takes care of the time like:
    if(time-5:0,0,my_expression)
  • Jesper Slattengren
    0 Jesper Slattengren over 6 years ago
    Or even more flexible:
    MAX(.model.analysis.my_request.values[VALI(.model.analysis.TIME.values,5.0):MAXI(.model.analysis.TIME.values)])
