  2. Adams
  3. Is there a possibility to write the value of the Adams/Variable...
  • Subscribers 3
  • Views 2
Is there a possibility to write the value of the Adams/Variable in the Excel file?
4ondrej.petergac
4ondrej.petergac over 6 years ago
Is there a way to write the value of the adams variable in the excel file?
For example I want to write list of variable values in the excel file is there any way how I can do it?
Thanks and best regards,
Ondrej
  • jozef.bucha
    0 jozef.bucha over 6 years ago
    Hello Ondrej,
    Adams contains openpyxl
    openpyxl.readthedocs.io/.../
    you can use it directly from command line in adams
    for example this should create test.xlsx in working dir:
    from openpyxl import Workbook
    wb = Workbook()
    dest_filename = 'test.xlsx'
    wb.save(filename=dest_filename)
    Jozef
  • Thomas Nygårds
    0 Thomas Nygårds over 6 years ago
    Hi Ondrej!
    I saw that Jozef was quicker that I, and I agree if you are going to to something extensive then use openpyxl directly. If you are doing something quick and want to use only adams command language you can do like below:
    You can write numerical values like this:
    aexplore xlsx real_value write &
    xlsx_file = "Test_view_variable.xlsx" &
    sheet_name = "my_sheet" &
    worksheet_python_object = "None" &
    real_value = (eval(.my_variable)) &
    top_left_cell = "A1" &
    data_direction = vertical
    and string values like this:
    aexplore xlsx string_value write &
    string_value = "hello" &
    top_left_cell = "B2" &
    if you are working on an already open workbook you can use the
      worksheet_object_name = "ws" &
    input instead of inputs
    (but do not forget to save it)
    and you can use indexing like this:
      top_left_row = 1 &
      top_left_column = 2 &
    instead of cell address like this
    Regards
    Thomas
  • 4ondrej.petergac
    0 4ondrej.petergac over 6 years ago
    Hi Jozef and Thomas,
    thanks a lot for your responses and examples.
    Best regards,
    Ondrej
