  2. Adams
  3. Is it possible to run multiple ADAMs FMUs on one machine...
  • Subscribers 3
  • Views 3
Is it possible to run multiple ADAMs FMUs on one machine?
crukas
crukas over 6 years ago
I've been running ADAMs FMUs with other software and it seems like even if I rename the FMU and run it in a separate folder, I can't run a second simulation in parallel. Has anyone had success running 2 of the same FMUs (copy/pasted separate folders) at the same time?
  • Jesper Slattengren
    0 Jesper Slattengren over 6 years ago
    Obvious question: Do you have enough licenses available to run multiple instances of ADAMS/Solver?
  • crukas
    0 crukas over 6 years ago
    Yes, more than sufficient. We regularly submit jobs to an HPC and have multiple users within the organization. I've only seen licenses run out when responding to critical issues or non-moveable deadlines.
    Then it sounds like a support case. There should be no reason to not be able to run multiple FMUs, either in different models or in the same model.
