  2. Adams
  3. i am running doe in adams view through adams insight. it...
  • Subscribers 3
  • Views 3
i am running doe in adams view through adams insight. it gives following warning. but no such result file .last_run_2 exist in model.
vinod.sherekar
vinod.sherekar over 5 years ago
model is fresh without any analysis. still it is giving warning. After importing single results file in postprocessor two  files get imported. with same name. please suggest solution. please also comment on first warning
Capture
  • Jesper Slattengren
    0 Jesper Slattengren over 5 years ago
    There won't be a "file" named last_run_2. This happens when you change the model through an acf-command during the simulation. Adams then splits the results in two (even though it is technically one file and one run.
    To avoid this, add
    output/noseparator
    to your model or acf file. That forces Adams to treat it as one continuous analysis.
  • vinod.sherekar
    0 vinod.sherekar over 5 years ago
    Thank you very much. It works.
