  2. Adams
  3. Is it possible in adm the design variable is in usage ?
  • Subscribers 3
  • Views 120
zhenhui xu
zhenhui xu over 4 years ago
hello everyone,
Coule I ask , is it possible in adm the design variable is in usage ?
For example, I assign one design varialbe to define the spring stiffness, then expert adm and acf for file only simulation. Background: I want to change the design variable in .acf
  • Maziar R
    0 Maziar R over 4 years ago
    Design variables are evaluated to their values (real, int, string, etc.) when exported to ADM.
    If you would like to change anything during run time, you can use Adams Solver commands to do so. For list of available Adams Solver commands and their available arguments and options, please refer to the Adams Online Help and navigate to:
    Adams Basic Package > Adams Solver > Welcome to the C++ Version of Adams Solver > C++ Commands
    Thank you,
    Maziar
  • zhenhui xu
    0 zhenhui xu over 4 years ago
    Hi, Maziar
    Thanks for your answer.
    Did you mean, Adams Solver command is written into .acf  to change anything during run time?
  • Maziar R
    Adams Solver commands are output into ACF files to change what is supported by Adams Solver Commands listed at in Adams Online Help at:
