  2. Adams
  3. What has been improved from Adams 2017 to 2022, which affects...
  • Subscribers 3
  • Views 185
What has been improved from Adams 2017 to 2022, which affects Adams's results?
Abbas Shafiee
Abbas Shafiee over 4 years ago
  • Alexis Del Rio
    0 Alexis Del Rio over 4 years ago
    There are plenty of documentation about the enhancement topic
    What do you mean by 'affect'? what are you attempting to do?
  • Abbas Shafiee
    0 Abbas Shafiee over 4 years ago
    I am running two exactly similar models with exactly similar simulation settings one in Adams 2017 and one in Adams 2022. I plot the results from these two versions and visibly they are not the same. I understand it is OK if the results from two different versions are not on top of one another, but the difference is somehow I would like to understand what the main sources are causing this conspicuous difference.
  • Henrik.Skovbjerg
    0 Henrik.Skovbjerg over 4 years ago
    Is the model fully converged? If you tighten the error tolerance it should still give the same results.
    Do this in both versions of Adams.
    simcompanion.hexagon.com/.../confirmation-of-converged-solution--kb8016233
  • Abbas Shafiee
    Yes, the models are fully converged in both versions.
    Thank you for the document.
  • MartinKieltsch
    0 MartinKieltsch over 4 years ago
    My favorite wording for introducing things that make models not work properly any more in new versions is more like "enworsement".
    Are you by any chance using the f77 solver on 2017 and c++ in 2022 ? The latter one does require pretty different settings and I often saw deviations between results.
    Easiest example.
    Create a simple pendulum example (1 link, 1 revolute, gravity) and run it in A/View with 5s and 50 steps.
    Check amplitide of angular movement vs time. It's decreasing though we had no damping.
    Change to something like 5000 steps and everything is fine.
    You could also tighten error on the 50 step solution to get there.
    Using the f77 solver worked fine without any adjustments.
    If tuning the parameters did not help, contact MSC for assistance. They love validation models to challenge their solver.
