  2. Adams
  3. How can I build 4 dimension spline to lookup table
  • State Verified Answer
  • Subscribers 3
  • Views 135
zhenhui xu
zhenhui xu over 4 years ago
Hello ,everyone
I want to use multi dimension(4D) spline to look up the data.
That means there are three independent value to find out one output
Are there any example or demo for that i can learn?
Thanks a lot.
Kind Regards,
Zhenhui Xu
  • MartinKieltsch
    0 MartinKieltsch over 4 years ago
    That sounds like an application for a spline_read usersub.
    Depending on what element you require, you could also use a varsub, gfosub, sfosub, ....
    If I was stuck to standard ADAMS elements, I'd try to evaluate several splines separately and use a solver variable to "interpolate between" these single splines.
    For example you could use 2 3D splines that both use dimension #4 as the Z-axis and the variable would simply do a
    func = "(AKISPL(spline_1) + AKISPL(spline_2)) / 2"
    Another way to skin the cat could be to use 3 2D splines for the 3 dimensions (being all dependent on dimension #4) and "interpolate" that with an own algorithm (in the simplest form "(AKISPL(spline_1) + AKISPL(spline_2) + + AKISPL(spline_3)) / 3")
  • zhenhui xu
    0 zhenhui xu over 4 years ago
    Hr Kieltsch,
    thanks for your suggenstion.
    I have used 2 3D methode which you mentioned to deal with my case. ​
