  2. Adams
  3. Force graphical update after running Adams Python script...
  • Subscribers 3
  • Views 240
Force graphical update after running Adams Python script?
michael.w.clarke1
michael.w.clarke1 over 1 year ago
I'm using the adams python API to build a large assembly of discretized parts (ie a rope or chain).  All of the markers in the assembly are parameterized using LOC_RELATIVE_TO and ORI_RELATIVE_TO.  Immediately after running the python script a bunch of random markers are shown as being oriented with global coordinates instead of adhering to their ORI_RELATIVE_TO expression.  If I manually modify the markers individually (painful as there are hundreds of markers) or run a simulation they will suddenly correct themselves to show the proper orientation specified by ORI_RELATIVE_TO for the rest of the Aview session.  Is there a command that I can run to force Adams to redraw everything after running the python script?
  • Alexis Del Rio
    0 Alexis Del Rio over 1 year ago
    what happens if you export a cmd file? how does the location appears?
    thanks
  • michael.w.clarke1
    0 michael.w.clarke1 over 1 year ago in reply to Alexis Del Rio
    If I export to cmd and re-import the cmd the markers are all aligned correctly. I see the ORI_RELATIVE_TO expressions as expected in the cmd language.  It appears that the python function isn't triggering some sort of update function in the graphics window.
  • Alexis Del Rio
    0 Alexis Del Rio over 1 year ago in reply to michael.w.clarke1
    So, if you review the cmd file in Notepad it's written correctly, that's good.
    What happens if:
    1. Close Information & Marker Modify
    2. Click the Groups tab
    3. Click Browse again
    4. then review Marker Modify/information, does it get updated?
  • michael.w.clarke1
    It seems like right click/modify on a marker (and closing the modify dialog box without changing anything, not even hitting ok or apply etc) will force the orientation of that marker to correct itself (and every other marker on that part too) in the graphics window. Doing this manually isn't feasible as the python script creates dozens of parts.
    Switching between groups/browse doesn't seem to effect anything, the right click/modify thing works with or without doing that.
  • MartinKieltsch
    0 MartinKieltsch over 1 year ago
    I use
    model display model model = .xxx
    for such purposes.
