  2. Adams
  3. How to model a spring and ball fitted inside a box which...
  • Subscribers 3
  • Views 171
How to model a spring and ball fitted inside a box which is pressed to a steel surface (guide bush with crator for the ball to roll into)?
Abhishek Kumar
Abhishek Kumar over 1 year ago
While modelling PTO shifting mechanism in tractor I need to model a box fitted with spring loaded steel ball (diameter 10 mm) which is pressed against a surface (of guide bush). The surface has small seating or crator in which ball can rest and mechanism can latch to that position. While shifting, there will be relative motion between the surface and the box fitted with spring loaded ball until it rolls inside one of the seating. The stiffness of spring is 4.4 (kg/mm). While I can model the system with general solid to solid contact, I would like to know if there is a better method to model such interactions. Also, if I need to model contacts, what should be the parameters for steel to steel.
Thanks in advance!
Regards
Abhishek
  • Jesper Slattengren
    Jesper Slattengren over 1 year ago +1
    Download HertzWin from https://vinksda.com/toolkit-mechanical-calculations/hertz-contact-stress-calculations/ and use that to calculate your stiffness and exponent. It is dependent on geometry as well…
    0 Jesper Slattengren over 1 year ago
    Download HertzWin from https://vinksda.com/toolkit-mechanical-calculations/hertz-contact-stress-calculations/ and use that to calculate your stiffness and exponent. It is dependent on geometry as well as materials.
    After selecting materials and the geometry, use the plot functionality, select Force <-> Impression and then export to a csv file. Open in Excel and create a power trendline. Turn on "Display Equation on Chart" and red off the stiffness and exponent. (Note that you have to plot Force vs Impression in Excel.
  • Abhishek Kumar
    0 Abhishek Kumar over 1 year ago in reply to Jesper Slattengren
    Thankyou, I will try to do it.
