  2. Adams
  3. mysolver.def(15) : fatal error LNK1118: syntax error in...
  • Replies 12
  • Subscribers 3
  • Views 19
mysolver.def(15) : fatal error LNK1118: syntax error in 'VERSION' statement
arbnor.balaj
arbnor.balaj over 7 years ago
Hello MSC Community,
I would like to reproduce a given example to generate a DLL from a user-written subroutine and at the last steps, I get an error.
Here the details:
Initial situation:
  • The example I do have ran under Windows 7 Professional Service Pack 1 (64bit) with the compiler: Microsoft Visual Studio 2017 Community Edition; and with the Adams version: Adams2017.2,
  • My OS: Windows 7 Enterprise Service Pack 1 (64bit),
  • My Compiler: Microsoft Windows SDK v7.1 (see installation information in “sdk-compiler-information.txt”),
  • My Adams version: Adams2018,
  • The Example is an user-written subroutine and is written in C. I will call this file "file.c".
My steps taken:
  • I opened the command prompt "Windows SDK 7.1 Command Prompt CMD Shell Optimized for Windows SDK" from the SDK installation folder.
  • In the command prompt, I went to the "file.c" directory with the command "cd" (C:\Users\Username\Desktop\).
  • Preparation for the compile step: I executed the command " Set NO_FORTRAN=1".
  • Compile step: "cl /c /Ox /MD file.c"; This step generated an object-file called "file.obj"
  • Link step: With the command "adams2018 cr-u n file.obj -n file.dll" I tried to generate a Libary which is called "file.dll". This step generated the following:
    • file.dll,
    • mysolver.bat,
    • mysolver.def.
The error occurs after the execution of the command from the last step. For the whole report of the command prompt after this step please look at the file “Error.txt”
Result: I generated a complete empty DLL (0kb) and normally it should have like 28kb.
These steps were given to me and except for small changes, I did copy the given steps. The differences to the given steps are the following:
  • In the example, an additional step had to be carried out. The step was to set the right environment for the compiler and for this the Batch-File "vcvars64.bat" was executed.
  • Example command: "adams2017_2 cr-u n file.obj -n file.dll" --> My command: "adams2018_1_SE cr-u n file.obj -n file.dll"
  • In the example, the own command prompt from Adams was used to execute the whole steps. I couldn't do this, because I didn’t have the admin permissions to execute "vcvars64.bat" (For now my workplace is in a university where I don’t have any admin permissions). In the end, I decided to get along with the SDK compiler that was the only available except my access to my private notebook which will be mentioned later on.
My tries to get rid of the error:
  • I added "/EHsc" in the compile command --> "cl /c /Ox /MD /EHsc file.c". I still did get the same error and same results.
  • I did execute the whole steps again in a new setup, which is available to me with my private notebook. The new set up is:
  • OS: Windows 7 N Professional Service Pack 1 (64bit)
    • Compiler: Microsoft Visual Studio 2017 Community Edition (same as from the example)
    • Adams version: Adams 2018.1 Student Edition (The Technical Support told me the academic license is permissible for my intention)
--> First, for this setup, I used the own Adams command prompt from the installation folder (C:\Program Files\MSC.Software\Adams Student Edition\2018_1\common\AdamsSetup.bat)
--> Next, for the setup, I used the VS command prompt "x86 Native Tools Command Prompt for VS 2017". For this first I had to execute the Batch-file "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars64.bat” to set up the 64bit environment.
==> Results of these two modes in this new setup: The same error occurs (mysolver.def(15) : fatal error LNK1118: syntax error in 'VERSION' statement)
If you can give me some hints, I would be very happy.
Thank you!
Kind regards,
A. Balaj
Attached Files (1)
Text-Data.zip
  • Jesper Slattengren
    0 Jesper Slattengren over 7 years ago
    I don't have the tools installed yet on my new computer, but I believe that you have to do this from the SDK command prompt.
    This is what I found in a SOP that I wrote some years ago
    1. Set the system variable NO_FORTRAN=1 (right-click on “Computer” à Properties à Advanced System Settings à Environment Variables; In the “System Variables” click “New”, enter NO_FORTRAN as variable name and 1 as the value). This tells ADAMS that no Fortran compiler is available and that it shouldn’t look for associated libraries.
    2. Install Visual Studio 2010 Express. Can be found on S: drive (maybe) or better directly from Microsoft’s webpage. www.microsoft.com/.../express . This will install the 32bit version of the compiler. If you run a 32 bit platform, you can stop now.
    3. For 64-bit support, you need to install the Microsoft Windows SDK 7.1 that has all 64 bit libraries. www.microsoft.com/.../details.aspx
    4. Run the compile and linking from the SDK command window where ‘cl’ now returns 64 bit version.
    a. Open the “Windows SDK 7.1 Command Prompt” (I have a shortcut on my desktop). Cd to your working directory and use “cl” for compiling with the switches specified at the ADAMS prompt.
    b. Link using the ADAMS start command, but do it from the SDK command prompt.
  • arbnor.balaj
    0 arbnor.balaj over 7 years ago
    thank you for your comment.
    Actually, I did use the SDK command prompt (see: "....I opened the command prompt "Windows SDK 7.1 Command Prompt CMD Shell Optimized for Windows SDK..." from the SDK installation folder. ...) or rather I had to use it because there was no other compiler in my university computer available.
    Regards, A.Balaj
  • MK202610123211
    0 MK202610123211 over 7 years ago
    If I were working at MSC support, I'd post this link
    simcompanion.mscsoftware.com/.../index
    saying that the supported compiler for ADAMS 2018 is solely
    Microsoft Visual Studio Professional 2015, Version 14.0.25420.01, Update 3.
    As I'm not working for MSC, I can add:
    Where's the problem in spending a 3 digit amount for software after having organized a 5 digit annual fee for ADAMS ?
    And a reminder to MSC: Since long I articulated that it'd be very handy to distribute the required C/Fortran compiler directly by MSC.
  • arbnor.balaj
    link: simcompanion.mscsoftware.com/.../index
    In this link you can see that the Community Edition is supported too.
    [...Adams 2018.1 officially supports the Professional Edition of Microsoft Visual Studio 2017, but the Community Edition 2017 has been found to function in the following scenarios:
    • DLL generation for user-written subroutines in C or in C and Fortran...]
    Furthermore, I have some new informations for my Topic.
    Acutally I did compile an example from the Adams installation folder (...\solver\c_usersubs\) without any errors. That was done in my private notebook with the setup mentioned.
    This shows that on my private notebook the hard- and software should be correct.
    In the end, I still don't know why I get the error mentioned with file.c.
    File.c  is a proven example  and  it must work with me too.
    Regards, A.Balaj​
