  2. AutoMesh
  3. Fidelity Mesh Control
  • Subscribers 7
  • Views 143
Gaurav
Gaurav 20 days ago
When should Volume mesh, Surface mesh, and 2.5D mesh be used?
  • Gaurav
    Gaurav 3 days ago
    Volume mesh: Generates a 3D mesh throughout the domain.
    Surface mesh: Generates a mesh only on the geometry surfaces. Choose Wrapping to create a clean surface without generating the entire 3D mesh. If Wrapping produces critical surface-quality issues, use Extraction from volume mesh, which is more robust but slower.
    2.5D mesh: Generates a 2D mesh with thickness in the third direction. The geometry must have two opposite, flat, parallel boundaries defined as Mirror or Periodic by translation. Use Number of layers in the 3rd direction to specify the cell layers across the thickness.
