  2. AutoMesh
  3. Why do the Mesh properties tabs change when I select different...
  • Subscribers 7
  • Views 31
Why do the Mesh properties tabs change when I select different items in the Mesh Setup tree?
Gaurav
Gaurav 1 day ago
I'm setting up a mesh, and the Mesh properties panel seems to change depending on what I select in the tree:
When I select the Mesh Setup, I see Global, Local, Control, and Output.
When I select a Domain, only Domain and Local appear.
When I select a surface, only Local appears.
I've also seen a Probe tab mentioned, but it doesn't show up.
Which tabs should be available for each item in the tree?
How do I make the Probe tab appear?
Why are some settings, like Far field treatment, greyed out?
