  2. MSC Apex
  3. Upon launching Apex Grizzly, why does it ask to insert a...
  • Replies 7
  • Subscribers 2
  • Views 100
Upon launching Apex Grizzly, why does it ask to insert a disk?
david.j.robocker.ctr
david.j.robocker.ctr over 8 years ago
  • Darrel Sinclair
    0 Darrel Sinclair over 8 years ago
    This is a bug which is triggered by issues with USB devices, and there are two known causes:
    1. Stale USB drive connection.  At some point a USB drive was connected, and when it was removed the connection wasn't completely cleared.  In this case, reconnecting any USB device usually allows Windows to refresh the connections.
    2. A device is connected via USB that Windows identifies as a disk drive, but which can't be accessed.  One example of this was a mobile phone that had been plugged in to a USB slot to charge.  Unplugging it stopped the error message coming up.  Subsequently plugging it in again did not cause the problem to recur.
  • david.j.robocker.ctr
    0 david.j.robocker.ctr over 8 years ago
    Darrel, do you know a way to clear stale USB drive connections besides going into the registry?
  • Darrel Sinclair
    Usually just plugging in any other USB device causes a refresh and makes the Apex error message go away. If that's not working, then perhaps a reboot might help?
    I had tried swapping the mouse and rebooting did not help. After swapping mouse, I uninstalled Apex Grizzly, rebooted, then reinstalled Apex, rebooted and same result.
  • Darrel Sinclair
    Sorry, I should have said any USB disk device. It's only USB devices that Windows recognises as disks that trigger and clear the problem. Can you try with a flash drive or external disk?
