  2. MSC Apex
  3. I'm getting an error every time a start Apex about incompatable...
  • Subscribers 2
  • Views 16
I'm getting an error every time a start Apex about incompatable (beta) database schema models. What should I do?
i.kelly
i.kelly over 8 years ago
The full text reads:
"Error Creating Default Model.
This may be due to incompatable (Beta) Database Schema versions. You may need to delete existing database and bootstrap files"
It then shuts down Apex.
Attached Files (1)
  • Darrel Sinclair
    0 Darrel Sinclair over 8 years ago
    The Apex lock server process is not running on your machine. This SimCompanion article gives details on how to get it working:
    simcompanion.mscsoftware.com/.../index
  • karlR
    0 karlR over 8 years ago
    Rename/Delete the "old" Apex config file "MSC_ApexConfig.xml" in the folder:
    %appdata%\..\local\msc\MSC_Apex
    If this does not help:
    re-install the Apex Lock server with the script "lsconfig.bat" in the folder <APEX_INSTALL_DIR>\Components\eom\WIN8664\bin
    Run this as administrator.
