  2. MSC Nastran
  3. ***SYSTEM FATAL MESSAGE 3008 (MODUG)
  • Subscribers 4
  • Views 36
Viplava
Viplava over 8 years ago
    INSUFFICIENT MEMORY AVAILABLE FOR SUBROUTINE MODUG
0FATAL ERROR
1                                       * * * END OF JOB * * *
 No Symbolic Replacement variables or values were specified.
*** SYSTEM INFORMATION MESSAGE 1156 (XCLNUP)
    GINO FILE     107 WAS LEFT OPEN AT PROGRAM TERMINATION.
Previously I ran similar Jobs with large number of Loadcases. Now I need to reduce the number of Loadcases because of this on Nastran2013r1. Why is adding ALTER the solution? Or is there any other alternative to run with all loadcases?
  • Don.Graff
    0 Don.Graff over 8 years ago
    There was an issue in v2013 where a very large SET could result in this error. Do you have a data request referencing a large SET? If so, try using ALL instead and see if that helps.
    This might be related to having a large number of CWELDS- do you have a lot of CWELDS? If so, the ALTER below can help but eliminates the CWELD results from data recovery.
    $ Nastran 2013r1 sol 101 alter to delete all MODUG references in subdmap sedisp
    compile sedisp nolist $
    alter 308,309 $
    alter 606,607 $
    alter 687,688 $
    The best thing might be to try a newer version of Nastran. Even the next release, v2014, should avoid this error if the root cause is either of the previously mentioned items.
  • Viplava
    0 Viplava over 8 years ago
    Hi Don.Graff,
    I used the above ALTER and it worked, and I dont have CWELDS. There are many CFASTs.​ But we keep solving the same size problem differently,  and this is the first model I encountered such error.
    Yes the SET is large, I will give you feedback if it works with ALL.
