  2. MSC Nastran
  3. Is it possible to create 2 static steps inside subcase in...
  • Subscribers 4
  • Views 35
Is it possible to create 2 static steps inside subcase in SOL 400?
pranayjoseph.vanukuri
pranayjoseph.vanukuri over 7 years ago
  • Hrishikesh Phadke
    0 Hrishikesh Phadke over 7 years ago
    Yes. You can do something like below.
    SOL 400
    CEND
    SUBCASE 1
    STEP 1
    ANALYSIS=NLSTAT
    SPC=XX
    LOAD=XX
    STEP 2
    ANLAYSIS=NLSTAT
    SPC=XX
    LOAD=XX
    In above case the results at the end of Step 1 will be carried to beginning of Step 2.
  • pranayjoseph.vanukuri
    0 pranayjoseph.vanukuri over 7 years ago
    I tried with the following but not getting required result
    SUBCASE 1
     STEP 1
      SUBTITLE=step_1
      ANALYSIS = NLSTATIC
      NLSTEP = 1
      SPC = 1
      LOAD = 3
      DISPLACEMENT(SORT1,REAL)=ALL
      SPCFORCES(SORT1,REAL)=ALL
      STRESS(SORT1,REAL,VONMISES,BILIN)=ALL
    $ Direct Text Input for this Step
     STEP 2
      SUBTITLE=step_2
      ANALYSIS = NLSTATIC
      NLSTEP = 2
      SPC = 1
      LOAD = 4
  • Hrishikesh Phadke
    Can you please clarify what is the required result? Also if you can attach the files, it will help to debug further....
    Just some information in case you might have missed it...
    LOAD=4..
    Make sure this is the additional Load + Load from Step 1..
    If you do not add the load from Step 1 in Step 2, it starts unloading the Step 1 load.
    Can you explain in more detail regarding "additional Load + Load from Step 1." I have created 2 load collectors first one I called in step1 and the second load in step2.
  • Hrishikesh Phadke
    Lets say in Step 1 you are applying Load 1 unit in X-direction and in Step 2 you want to apply Load 1 unit in Y-direction.
    In Step 1 LOAD=3 will call the Load 1 unit in X-direction.
    In Step 2 you are applying Load 1 unit in Y-direction.
    i.e LOAD=4.
    So LOAD=4 is Load 1 unit in X-direction + Load 1 unit in Y-direction
