  2. MSC Nastran
  3. Can anyone provide me example file for bolt preload with...
  • Subscribers 4
  • Views 42
Can anyone provide me example file for bolt preload with 1-d beam element?
pranayjoseph.vanukuri
pranayjoseph.vanukuri over 7 years ago
  • Hrishikesh Phadke
    0 Hrishikesh Phadke over 7 years ago
    Sample file attached.
    Attached Files (1)
    sol400_bolt.bdf.zip
  • pranayjoseph.vanukuri
    0 pranayjoseph.vanukuri over 7 years ago
    hi,
    Is there any example with BOLT, BOLTLD & BOLTFOR bulk entries?
    I try to use these commands in my simulation set up. Unfortunately I am getting below
    error.
    28908   SUBCASE 222717
           28909    BOLTLD = 222717
     *** USER FATAL MESSAGE 601 (IFP1D)
       THE KEYWORD ON THE ABOVE CARD TYPE IS ILLEGAL OR MISSPELLED.
           28910   $$----------------------------------------------------------------------    --------
           28911   $$           BULK DATA CARDS
           28912   $$----------------------------------------------------------------------    --------
           28913   BEGIN BULK
    I used SOL101 with AUTOMSET YES param card.
    can you please help me?
  • Hrishikesh Phadke
    BOLTLD/BOLTFOR are NX Nastran bulk data entries. So if you run this with MSC Nastran then you will get a FATAL.
    In MSC Nastran there is only BOLT entry in bulk data entry. This does not require any call in Case control section. See earlier example attached again.
    Do not use AUTOMSET, YES.
