  2. MSC Nastran
  3. can we compare participation values of different iterations...
  • Subscribers 3
  • Views 24
can we compare participation values of different iterations in DOE using SOL112?
maheshkumar.kavalgav
maheshkumar.kavalgav over 6 years ago
  • Sanjay Patel
    0 Sanjay Patel over 6 years ago
    Hi Maheshkumar,
    DOE in nastran is presented as option/method for discrete variable optimization. Computation of these discrete solution is based on the previous continuous solution. One can create a discrete variable optimization result after each continuous solution result by using DISBEG set to 1 in DOPTPRM entry. so this can be accomplised by looking at the results of each Discrete Design cycle results.
    Sanjay.
  • Sanjay Patel
    Transient solution does not land itself to optimization well as future response sensitivities are not accurately derived/predicted.
