  2. MSC Nastran
  3. sol200; fit accPSD response to test results
  • Subscribers 4
  • Views 41
adam.narozniak
adam.narozniak over 7 years ago
I have a 2 mass and 2 spring system which has test response specified in DABLED1​. I would like to find spring stiffneses to match the test result. How to define the objective function in such case?
Attached Files (1)
opt_fresp_02.dat
  • Martin MSC Nastran
    0 Martin MSC Nastran over 7 years ago
    See attached PDF. Slide S30 shows a setup. For your model you could use the table constraints on your response shown in S37.
    Attached Files (1)
    psd_sol200.pdf
  • adam.narozniak
    0 adam.narozniak over 7 years ago
    It does not work.​ If I make it like this:
    DCONSTR 800   801     17            20.    2000.
    DRESP1  801   PSDpar  PSDACCL 1000             3     MAX   2
    TABLED1 17     log    log
    +      20.    0.16   21.33  0.17   23.28  0.19   27.18  0.23   +
    +      72.37  2.41   84.49  7.71   92.24  34.09  98.36  237.82 +
    +      102.26 66.3   107.83 14.6   118.4  3.4    213.95 0.32   +
    +      234.92 0.65   247.71 1.91   257.52 5.02   279.72 0.24   +
    +      313.17 0.02   382.18 0.01   1347.62 0.01   1644.6 0.01   +
    +      1841.28 0.01   2000.  0.01   ENDT
    I got an error:
        "DCONSTR ASSOCIATED WITH DRESP1     801, AN IMPLIED DRESP2, CAN NOT REFERENCE TABLEDx ID IN LALLOW AND/OR UALLOW FIELDS.
        USER ACTION: SPECIFIC ALLOWABLES IN REAL NUMBER MUST BE PROVIDED ON DCONSTR FOR AN IMPLIED DRESP2."
    Attached Files (1)
    opt_rms_01.dat
  • Hrishikesh Phadke
    0 Hrishikesh Phadke over 7 years ago
    Attached modified file.
    DRESP1  801  PSDpar  PSDACCL 1000       3   10.   2
    This will work.
    MAX is not allowed. It can take input at specific freq only.
    Attached Files (1)
    opt_rms_01.dat
