  2. MSC Nastran
  3. Contact Modelling in SOL600
  • Subscribers 4
  • Views 18
dheeraj.kothapalli
dheeraj.kothapalli over 7 years ago
I am trying to solve for contact solution. I have defined contact pairs instead of using contact table format. I have defined three load steps that are needed to be run cumulative. I have licensing only for SOL600. So, when I tried to setup the job for SOL600, the .bdf file by default is printing BCONTACT = ALLBODY in each subacase by default. This does not work for me as I have contacts that are combination of touch and glue type and for all touching contact I have defined a coefficient of friction. But, when I tried to setup the job for SOL400, I have no issues. Please see attached for how the subcase and loadsetps are coming out for both the cases. I really need some assistance on how to get the contact setup work in SOL600 using Patran.
Attached Files (2)
SOL400.bdf.zip
SOL600.bdf.zip
  • zhong.qin
    0 zhong.qin over 7 years ago
    For sol600, you need to use contact table option.
