  2. Patran
  3. Is there a way to plot temperature differences between two...
  • Subscribers 3
  • Views 23
Is there a way to plot temperature differences between two different nrfs? Same mesh, same time point, just want to post the difference in metal temperatures after making a boundary change,
adham.a.fakhry
adham.a.fakhry over 7 years ago
  • edwin.goei
    0 edwin.goei over 7 years ago
    One way you can do this is by using Create > Results > Combine.
    Select the two Result Cases from the two NRFs, then in the table, enter a Factor of -1.0 for one of them, leaving the other as 1.0.
    Then click on the Temperature in "Select Results", click OK, and finally Apply on the main form.
    You will get a new subcase which will be the difference of the two.
    You can verify this by going to Create > Cursor > Scalar, then selecting the new subcase, selecting the Temperature for the Cursor Result, then picking a node. The node you pick should have the value that is the first temperature minus the second temperature..
    You can also do a Create > Fringe on the new subcase and it will also show you the new values, which is a difference of the two.
