  2. Patran
  3. I have a running model in which I have used tet10 mesh for...
  • State Verified Answer
  • Replies 7
  • Subscribers 3
  • Views 64
I have a running model in which I have used tet10 mesh for solid. Now based on my results I would like to refine (fine mesh) mesh on one solid object. Is there a way to do it without deleted the mesh on the body and remeshing it again?
shaheer.iqbal
shaheer.iqbal over 7 years ago
I have RBE2 and RBE3 connected to that solid geometry. If I deleted the mesh and mesh it again using small GEL value I get bad elements. (probably its picking up the RBE3 and RBE2 nodes already associated with that solid and creating bad elements.) Any way around for this?
  • edwin.goei
    0 edwin.goei over 7 years ago
    If you don't want to delete the mesh, you could conceivably use Utilities/FEM-Elements/Break Elements, Break/Tet/Split and use the middle Replacement Pattern, which creates 4 Tets about the element centroid. This would just increase the number of elements, creating a finer mesh without changing or moving the existing nodes.
  • shaheer.iqbal
    0 shaheer.iqbal over 7 years ago
    Thank you for the comment. I tried this and unfortunately it is not splitting. ​Msg I get that the element I am splitting is not a TET4 element. My element is TET10.
  • edwin.goei
    You can get around this as well. First go to Elements, then Modify/Element/Edit. Click on Type.
    For Shape, select Tet.
    For New Topology, select Tet4.
    Then select your Tet10s in "Element List" and click Apply.
    This will convert your Tet10s to Tet4s, which will allow you to split it with the Utility.
    Once you've done the split, go back to this menu and change the new Tet4s into Tet10s again.
  • shaheer.iqbal
    Thanks, I understood that its a two step process . few follow up questions.
    Since I modified few elements of that solid, do I need to associate the new elements/new nodes with the Solid?
    Do I need to equivalence the nodes?
    Thanks for all the help​
  • edwin.goei
    Yes, you do need to associate the new elements to the solid. You can use Elements, Associate/Elements/Solid, then pick all the elements and then the solid.
    I do not think you need to equivalence the nodes, but it wouldn't hurt to do an Equivalence to be sure everything is connected. Do a free edge check with Verify/Element/Boundaries to check for any interior cracks (there shouldn't be). Note that there will be dashed lines indicating free/shared edges on the exterior boundary, especially on the corners, but don't worry about those; these are natural.
