  2. Patran
  3. I am trying to model a cylindrical joint. Like an actuator...
  • Subscribers 3
  • Views 20
I am trying to model a cylindrical joint. Like an actuator that can only translate in 1 DOF. My cylinder joint length is ~10 inches and I am modelling it ONE CBUSH Element (BAR 2-topology)
shaheer.iqbal
shaheer.iqbal over 7 years ago
1) Is it correct to use 1 element and BAR2 topology?
2) I am giving it PBUSH Element type property and defining my 6 spring constant to determine ​the stiffness of the cylindrical joint. Is it a correct approach?
3) Since, it will be cylinder joint, I am defining a local LBC to restrict the motion in other 2 axes (so it only translates in one axis). What should I do with the Rotational DOF? little confused on this
Let me know if my approach is good, or is there a better way to tackle this. Thanks
  • Sanjay Patel
    0 Sanjay Patel over 7 years ago
    Hello Shaheer,
    BAR2 topology is fine. It would help create 1d elements including CBUSH. These type of connections are generally done via RJOINT. CBUSH/PBUSH will actually prevent the motion. Refer to the RJOINT in quick reference guide for details.
    Sanjay.
