  2. Patran
  3. FREE-FREE Modes
  • Subscribers 3
  • Views 32
FREE-FREE Modes
shaheer.iqbal
shaheer.iqbal over 7 years ago
Hello
I have a model that I am checking for any errors. I ran a free-free modal analysis. Instead of getting 6 rigid body modes (zero), I am getting the first 3 modes as 0 while, the other 3 (rotational) are not perfectly zero. It has a value of 0.2
Any recommendation on how to debug and know what is going on?​
  • Ken Walker
    0 Ken Walker over 7 years ago
    This could be a grounding problem caused by unintended internal constraints.
    Typical grounding causes are:
    • Ill-conditioned MPC’s
    • Incorrectly connected spring elements
    • Coordinate system errors (definition and/or references)
    • PS entry on GRID card (Permanent single-point constraint)
    • Improperly defined DMIG matrices (Superelement errors)
    To identify potential grounding problems, add GROUNDCHECK(SET=(G,N))=YES to your Nastran model (goes in CASE CONTROL). It has additional options; read the QRG for details. Look in f06 for PASS/FAIL under "RESULTS OF RIGID BODY CHECKS".
  • shaheer.iqbal
    0 shaheer.iqbal over 7 years ago
    Thank you for the response, So I debugged my model and found the following fix.
    • I was using glued contact within my model. I deleted the glued contact and put a RBE2 contact to attach the bodies and it fixed the error.
    • Any suggestion why would a glued contact not give perfect rigid body modes? ​
  • Ken Walker
    Short answer: you will get rigid modes any where 2 parts aren't successfully glued. There can be multiple causes. The most common include:
    1. Contact detection distance (ERROR) too small,
    2. Missing elements in contact bodies (BSURF),
    3. Incorrect IGLUE flag (need 2 or 4 for moment carrying glue with shells/bars).
    4. Incorrect contact options (COPTS/COPTM)
    To visualize contact status, include BOUTPUT=YES as a Case Control Result Request to get contact status for Subcase 0. Be sure to save results as HDF5 or OP2 to post-process.
