  2. Romax
  3. Roller bearing running on a shaft
  • State Verified Answer
  • Subscribers 2
  • Views 207
Kurt Sheridan
Kurt Sheridan over 1 year ago
I have a needle roller bearing running on a shaft (no inner race). The analysis says that the maximum raceway contact stress is 1178 MPa but the worst raceway contact stress static safety factor (Hertzian) is “Not applicable due to yield”. The maximum allowable stress between a roller and raceway per ISO 76 is 4000 MPa. Why am I getting this message?
This question and answer has been posted by Hexagon support for the benefit of our community members
  • Kurt Sheridan
    Kurt Sheridan over 1 year ago +1 verified
    In the analysis settings, under “General options” tab and then under the “Bearing Advanced” tab, you will find that “use ‘Enhanced contact analysis’” is turned on. Romax will use the shaft material properties…
  • Kurt Sheridan
    0 Kurt Sheridan over 1 year ago
    In the analysis settings, under “General options” tab and then under the “Bearing Advanced” tab, you will find that “use ‘Enhanced contact analysis’” is turned on. Romax will use the shaft material properties in determining the allowable yield stress because the shaft is the bearing inner race in this case.
    The allowable yield stress is calculated from the shaft material’s UCS (ultimate compressive strength) multiplied by the value show for “Factor to determine yield threshold from ultimate compressive strength” (the default value is 1.785714285714) to determine the yield point of the shaft.
    To achieve a yield point of 4000 MPa, the UCS would need to be 2240 MPa (2240 x 1.785714285714 = 4000) for the shaft material. You can make a new material (copy of the material you are using for the shaft but with the higher UCS) in the database and then specify that material be used for the shaft section(s) supporting the rollers. This represents the hardening of the shaft to properly support the rollers running directly on the shaft.
    For reference, the hardness of the shaft surface is usually required to be around Rc 62 by the bearing manufacturer so you should check to determine what they require for hardness and case depth of the shaft to properly support the bearing.
