  2. Romax
  3. Gear Rating
  • State Verified Answer
  • Subscribers 2
  • Views 273
Gear Rating
Pandurang Naik
Pandurang Naik 7 months ago
What is the difference between duty cycle safety factor and load case safety factor of a gear?
(This Q&A has been posted by Hexagon Technical Support for the benefit of our community members)
  • Pandurang Naik
    Pandurang Naik 7 months ago +1 verified
    Load case safety factor is calculated by considering permissible (allowable) stress and actual stress. Load case safety factor is = Permissible stress / Actual stress. Duty cycle safety factor is calculated…
  • Pandurang Naik
    0 Pandurang Naik 7 months ago
    Load case safety factor is calculated by considering permissible (allowable) stress and actual stress. Load case safety factor is = Permissible stress / Actual stress. Duty cycle safety factor is calculated by iterative method.
    Romax ensures that the total damage from all load cases equals 100% by applying an iterative method that uses a scaling factor. This scaling factor is referred to as the duty cycle safety factor. Please refer ISO 6336-6 section 5.4.
    For example, if the combined damage from all load cases exceeds 100%, Romax applies a scaling factor less than 1 to reduce the total damage to exactly 100%. The specific scaling factor at which the sum of damages equals 100% is defined as the duty cycle safety factor.
