  2. Simufact
  3. How to request specific output?
  • Subscribers 4
  • Views 142
ACopper
ACopper over 2 years ago
I would like to request specific output in my analysis in Simufact Welding. Instead of having a standard set of output variables, I want to limit my output request to a few parameters, for example, flow stress, maximum temperature, Z strain. How can this be achieved? What keyword/data block should I look for in the data file? Where can I find this information in Volume C: Program Input?
  • M B
    0 M B over 2 years ago
    Hello, you hopefully are aware that simufact welding is using sfMarc, which is based on but not the same as marc referenced in Volume C. As as result of this it unfortunately is not possible to limit the result output values in simufact welding, because a standard set of output variables is used.
