  2. Simufact
  3. Scripting for automatic preform generation based on die...
  • Replies 8
  • Subscribers 4
  • Views 538
Scripting for automatic preform generation based on die designs!
asam
asam over 2 years ago
Hello community!
I am not strong at scripting!
I am trying to optimize my forging preform models using scripting, may I know what would be the best modelling software which we can use to communicate between modelling software and Simufact Forming module?
Is there a process in Simufact itself which will help us to modify preforms based on strain constraints?
Vignesh.
  • Simufact Support
    0 Simufact Support over 2 years ago
    Hello Vignesh,
    Sorry for the late answer. I don't quite understand what you intend to do. With modeling software, do you mean CAD-software? Simufact Forming has its own Python scripting capabilities. This allows you to automate postprocessing and possibly to transfer data to another software. Simufact Forming has only few options to modify facetted STL data and can not work at all with analytical CAD data.
    Best Regards
    David
  • asam
    0 asam over 2 years ago
    Hello David,
    thank you for answering my question.
    my problem statement is:
    I am trying to design a preform based on my final die shape. I am creating a preform design in solid works and exporting the cad model into simufact hot forging module. Then I am performing my forging using hammer strike and looking into the final over all strain distribution. The main goal is to achieve a strain range from x-y through out the forged part. For that I have to change my preform shape based on material flow in the previous simulations. As this process takes multiple preforms to be generated and lot of time. I am trying to automate the preform generation process based on NURBS concept in solid-works. So now my question is does simufact interact with any modeling software and will perform simulations based on the newly created preforms by scripting it in the simufact python terminal? Or does Simufact has a similar concept where it will create a preform with strain distribution control parameters?
    thanks,
    vignesh
  • Simufact Support
    Simufact itself can not change the geometry as you would be able with your CAD-Software. With Python scripting you can export the strain results and also automatically create variants with different die geometries. How you feed the exported information into SolidWorks, I can not help you with.
  • asam
    Hello David,
    Thanks for your response.
    can we extract out results like overall strain in .txt format in forging?
    Vignesh.
  • Simufact Support
    Hello Vignesh,
    Yes this is possible. With the mesh class of our integrated python scripting, you can access node and integration point results.
    Best Regards
    David
