  2. Simufact
  3. How can i transform the Modified Mohr-Coulomb damage model...
  • Subscribers 4
  • Views 125
How can i transform the Modified Mohr-Coulomb damage model to be temperature dependent ?
Tolgahan CİVEK
Tolgahan CİVEK over 1 year ago
Hello Simufact Community,
I am trying to simulate a deep drawing process in which the temperature of the sheet metal varies during simulation. For that i have the flowcurves of the material for different temperatures. However, what i am mostly interested in is to see the fracture or the damage value in the specimen using the damage models. I have the parameters of the Modified Mohr-Coulomb damage model for room temperature and i can get them for elevated temperatures as well. But i can't find a way how to insert the parameters of the damage model for elevated temperatures in the material properties. I have checked for the subroutine models and found that i can use UDAMAG or ueloop subroutines to include a damage model that is not available in the material properties. However, i don't know how i can include the temperature parameter in either of the subroutines because these subroutine models do not contain temperature in their parameters.
I would be thankfull if anyone could help.
Sincerely,
  • Simufact Support
    0 Simufact Support over 1 year ago
    Hello Tolgahan,
    you can use the get_nodvar() utility routine to get nodal result values for your subroutines. You can find more information in Simufact Formings Scientific tutorial.
    David
