  2. Simufact
  3. Issues with scripting in simufact
  • Subscribers 4
  • Views 340
asam
asam over 1 year ago
Hello all,
 I am trying to save my results contours as images with the predefined saved view and applying it to all of them using the below script but not able to get the saved view apply to all of them:
import os
import traceback
# === Configuration ===
save_directory = r'C:\Users\ecslogin\OneDrive - Wright State University\PhD\Writing\IMECE 2025 Paper\V1\Results'
os.makedirs(save_directory, exist_ok=True)
# Define what to extract
result_value_list = [('EFFPLS', [0, 1]), ('TEMPTURE', 'AutomaticAllIncrements')]
increment_list = [('Forming', 100.0)]
save_images = True
save_animations = False
duration_value = 10
animation_mode_value = 'default'
process_names = []
# === Project Setup ===
project = current_project()
base_view_settings = project.result_view_settings('SavedViewA')
if base_view_settings is None:
    raise RuntimeError("X Error: 'SavedViewA' result view settings not found in project.")
# === Process Collection ===
process_list = [project.process(name=pn) for pn in process_names] if process_names else list(project.all_processes)
if not process_list:
    raise RuntimeError("X No processes found to run analysis on.")
print("Open file folder Processes found:", [p.name for p in process_list])
# === Main Loop ===
for process in process_list:
    try:
        print(f"\nArrows counterclockwise Starting: {process.name}")
        # Run analysis if not already done
        if process.results is None:
            print(f"Hourglass flowing sand Running analysis for: {process.name}")
            analysis = process.start_analysis()
            analysis.wait()
            print(f"White check mark Analysis complete for: {process.name}")
        # Open result view for this process (default view only)
        result_view = process.open_result_view()
        for result_value, legend_bounds in result_value_list:
            result_value_name = result_value[0]
            # Clone settings from SavedViewA
            settings = base_view_settings.copy()
            settings.set_result_value(result_value=result_value_name, legend_bounds=legend_bounds)
            for loadcase_name, loadcase_percent in increment_list:
                settings.increment_loadcase = loadcase_name
                settings.increment_percent = loadcase_percent
                if save_images:
                    filename = os.path.join(
                        save_directory,
                        f"{process.name}_{result_value_name}_{loadcase_name}_{loadcase_percent}.png"
                    print(f"Camera with flash Saving image: {filename}")
                    result_view.save_to_image(filename=filename, settings=settings)
                if save_animations:
                    anim_file = os.path.join(
                        save_directory,
                        f"{process.name}_{result_value_name}.avi"
                    print(f"Film frames️ Saving animation: {anim_file}")
                    result_view.save_animation(
                        filename=anim_file,
                        duration=duration_value,
                        animation_mode=animation_mode_value,
                        settings=settings
            # Clean up cloned settings object
            project.delete_result_view_settings(settings)
        result_view.close()
        print(f"Heavy check mark Finished: {process.name}")
    except Exception as e:
        print(f"X Error in {process.name}: {e}")
        traceback.print_exc()
print("\nWhite check mark Script completed for all processes.")
  • asam
    0 asam over 1 year ago
    But when I use the following script after fixing the issue my software closes after my first process simulation, can someone please help with this issue?
    import os
    import traceback
    # Define which result types and loadcases you want images for
    result_value_list = ['EFFPLS', 'TEMPTURE']
    save_images = True
    duration_value = 10
    process_names = []
    # === Main Processing Loop ===
        try:
            print(f"\nArrows counterclockwise Processing: {process.name}")
            # Run analysis if needed
                analysis.wait()
            # Open result view using SavedViewA (template style)
            result_view = process.open_result_view(base_view_settings)
            for result_value in result_value_list:
                    # Use the SavedViewA settings as-is without modifications
                    # Just apply it to each image you save
                    if save_images:
                            save_directory,
                            f"{process.name}_{result_value}_{loadcase_name}_{loadcase_percent}.png"
                        result_view.save_to_image(filename=filename, settings=base_view_settings)
                    if save_animations:
                            save_directory,
                            f"{process.name}_{result_value}.avi"
                            filename=anim_file,
            result_view.close()
  • M B
    0 M B over 1 year ago in reply to asam
    Hello Asam,
    I tested the code you provided her on my side.
    it looks like there is a bug with the python command in the line I quoted. I will report this to the development team. Please use the command
    save_result_view_to_image(process="UpsettingFe3D", filename=r'D:\image.png', resolution=(1920, 1080), settings=settings_obj) instead.
  • asam
    0 asam over 1 year ago in reply to M B
    I was able to run it but i couldn't find any images in the location:
    >>> Run: C:/Users/ecslogin/OneDrive - Wright State University/PhD/Writing/IMECE 2025 Paper/V1/Results/Test_run_all.py
    Open file folder Processes found: ['ForgingFe3D-2', 'ForgingFe3D-4', 'ForgingFe3D-6', 'ForgingFe3D-7', 'ForgingFe3D-9', 'ForgingFe3D-10', 'ForgingFe3D-10-fric0-1', 'ForgingFe3D-10-fric0-2', 'ForgingFe3D-10-fric0-4']
    Arrows counterclockwise Processing: ForgingFe3D-2
    Camera with flash Saving image: C:\Users\ecslogin\OneDrive - Wright State University\PhD\Writing\IMECE 2025 Paper\V1\Results\ForgingFe3D-2_EFFPLS_Forming_100.0.png
    Camera with flash Saving image: C:\Users\ecslogin\OneDrive - Wright State University\PhD\Writing\IMECE 2025 Paper\V1\Results\ForgingFe3D-2_TEMPTURE_Forming_100.0.png
    Heavy check mark Finished: ForgingFe3D-2
  • asam
    0 asam over 1 year ago in reply to asam
    Its working now i had to change my process line command
    save_result_view_to_image(process=process.name , filename=filename, resolution=(1920, 1080), settings=base_view_settings)
    thank you!
