  2. Simufact
  3. Double ellipsoid goldak model in Simufact welding DED (WAAM...
  • Subscribers 4
  • Views 293
Double ellipsoid goldak model in Simufact welding DED (WAAM)
asam
asam over 1 year ago
Hello all,
I am trying to simulate a Wire Arc Additive manufacturing of a 11*11*2" plate to look in to the residual stresses across the entire geometry.
I have the process parameters for the movement do I also need to input the heat source parameters by physically measuring them of a single weld bead? Doesn't the software calculate the heat source based on the process parameters and Rosenthal?
Vignesh.
  • J Z
    0 J Z over 1 year ago
    Hi Vignesh,
    yes you need to define the dimension of heat source based on measurement.
    Simufact Welding cannot calculate it only based on process parameter.
    Regards
    JZ
  • JL
    0 JL over 1 year ago
    Hi Vignesh,
    for  WAAM processes, you can also use the track width and high as a reference for the size of the heat source. Sometimes it's more comfortable to use a cylindrical heat source instead of the double ellipsoid as the cylindrical shape matches the track size better.
