  2. Simufact
  3. CNN gray scale images for strain contour plots.
  • Subscribers 4
  • Views 212
asam
asam over 1 year ago
I am trying to run a CNN for my forging preform optimization, I would like to have a dataset of my strain contour plots in a range of x-y, is there a way to save the strain contour plots in the gray scale form directly from the result section?
I am trying to replicate the model similar to the one in the following published journal figure 3.
Vignesh nexus.hexagon.com/.../CNN_2D00_Based-Innovative-Preform-Design-for-uniform-strain-distribution-in-flex-spline-forgings.pdf
  • C B
    0 C B over 1 year ago
    Hi Vignesh,
    in the color legend properties of Simufact Forming you can select to use a grayscale legend type. Combined with a black or white background this should get you close to "figure 3". You can set the colors of dies to black, too. If you have a 3d model, you can use a clipping plane with the "cut plane" option to see only the results in a specified plane.
    I hope I got your question right. I did not make my way thru the whole publication.
    Christian
