  2. Simufact
  3. Hydroforming using a simple-shaped tube
  • State Verified Answer
  • Subscribers 4
  • Views 290
Akiho Morita
Akiho Morita 4 months ago
Is it possible to HydroForming analysis with 2D-axisymmetric condition?
I have recently been running simulations of hydroforming with a simple-shaped tube as an exercise.
Now I select "3D" for simulation type, and fluid pressure is applied to the inner surface as a surface load acting as a boundary condition.
Since the shape is perfectly axisymmetric, I want to do an axisymmetric analysis if it's possible.
However, if I select the 2D axisymmetric simulation type, surface loads can only be applied in the circumferential direction.
I need to apply the load in the radial direction.
Please teach me if you know a good way to do this.
I use "Simufact Forming 2026.2".
  • M B
    M B 4 months ago +1 verified
    Hi Akito, No, it's not possible to define face load for 2d axis symmetric processes. The only workaround I can offer is to use a point load and calculate the force based on your element size, if X,Y…
  • M B
    0 M B 4 months ago
    Hi Akito,
    No, it's not possible to define face load for 2d axis symmetric processes. The only workaround I can offer is to use a point load and calculate the force based on your element size, if X,Y or Z matches the radial direction.
