  2. Celsius Thermal Solver
  3. Cooling your Electronics Systems
  • Subscribers 14
  • Views 8817
SimTech
SimTech over 4 years ago
Thermal radiation heat transfer is a heat transfer method that plays an important role in the thermal managment of certain electronicd devices. The efficiency with which electronics cool can be improved by utilizing radiation heat transfers. Thermal radiation heat transfers contribute to low-air velocity and natural convection applications. Similar to other heat transfer methods such as conduction and convection, the temperature difference between an object and its surroundings matters in the radiation cooling of electronic circuits. Apart from the temperature difference, the surface texture of the electronic circuit or chassis and the view of the surroundings also influence thermal radiation heat transfers.
Click here to learn more about the factors influencing heat transfer.
  • SimTech
    SimTech over 3 years ago
    Celsius Thermal Solver can help you understand heat transfer in your electronics. It can also help optimize the design while all three modes of heat transfer are considered. To know more about Celsius Thermal Solver, you can refer to the following post: What is celsius thermal solver?
