  2. Celsius Thermal Solver
  3. Parameterizing your design in Celsius
  • Subscribers 14
  • Views 4003
SimTech
SimTech over 2 years ago
Celsius allows user to run parametric studies on your design to see how it behaves at different variable values. Instead of simulating the design multiple times using different values, you can set sweep parameters for the geometries, materials, or boundary conditions in the design, and the tool will automatically create multiple cases and run sweep simulation for the generated cases.
The boundary conditions that support parameterization are: Static Power and Temperature, Heat Transfer Coefficient (HTC), and VRM/Sink Patch.
Celsius Thermal Solver User Guide mentions the steps for defining sweep parameters for geometries, boundary conditions, and material properties.
